View the area advertisements and other information in the LSDB to ensure correct OSPF operations.
  • To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  • The VRF must have an RP trigger of OSPF.
  1. In the navigation pane, expand Configuration > IP.
  2. Select OSPF.
  3. Select the Link State Database tab.
Link State Database Field Descriptions
Use the data in the following table to use the Link State Database tab.
Name
Description
AreaId
Identifies the area. The OSPF backbone uses the area ID 0.0.0.0.
Type
Specifies the OSPF interface type. Broadcast LANs, such as Ethernet and IEEE 802.5, use broadcast; X.25 and similar technologies use NBMA; and links that are point-to-point use pointToPoint.
Lsid
Identifies the piece of the routing domain that the advertisement describes.
RouterId
Identifies the router in the autonomous system.
Sequence
Identifies old and duplicate link-state advertisements.
Age
Specifies the age, in seconds, of the link-state advertisement.
Checksum
Contains the checksum of the complete contents of the advertisement, except for the age parameter. The checksum does not include the age parameter so that advertisement age increments without updating the checksum.
